Altair RISE
Nominate Yourself Now!
Copy Multiple Files add Date Stamp
User: "Altair Forum User"
Altair Employee
Updated by Altair Forum User
I have the below.
Six input files to be copied to a folder that is a named export (ignore that it says email in the image.)
This is not a problem and works just fine.
What I would like though is to add the date to each file name. (ex "Test" becomes "Test120517")
I know how to do this for a single file, but I'm unsure how to proceed with multiple files.
They do not work their way through a Workspace or Model just a simple copy.
Thanks-
1 - 3 of 31
    Altair Employee
    OP
    Craig,
    You can accomplish this by using either the standard process design (SPD) or the visual process Design (VPD)
    In a VPD configure the hub's File input processing to individually
    Configure the distribution and add &[Source.name] macro followed by the date macro in the rename as box.
    In SPD configure the input tab in the project editor to each in its own job
    Add a copy distribution and add the &[source.name] macro followed by the date macro in the rename file as.
    Regards
    Mo
    Altair Employee
    OP
    Craig,
    Regards
    Mo
    Altair Employee
    OP
    Kenjie Bermundo led me to the solution above.  Using [souce.name] in the rename field.
