Qsub multiple jobs from HyperStudy on Linux Cluster
Hi everyone,
I'm trying to run multiple jobs on my PC cluster which works with linux shell (bash). I use HyperStudy to parametrize input file.k and then run it with Ls-Dyna Solver. It works automatically on local PC, but I'm struggling so much to make the submission on cluster PC. Usually, when I want to run a single job I submit it via my script file named "single". In this way, writing in the prompt:
qsub single
I can see the job running.
I tried modifying a bit my script to make it useful with the files.k stored in the nested folders created by HyperStudy. I have successfully created the directories and imported the files correctly in each folder from the ssh protocol connection, but the jobs still don't run. I report the error files I get:
*> [compute-0-2.local:15366] Warning: could not find environment variable "LSTC_LICENSE_SERVER"* *> [compute-0-2.local:15366] Warning: could not find environment variable "LSTC_LICENSE"* *> /var/spool/torque/mom_priv/jobs/16308.archimede.pcmgroup.dmti.unifi.it.SC: line 35: l2a_r712: command not found*
It sounds really strange because I don't get any of this when I run single jobs, but maybe I miss something as I'm not an expert linux coder.
Any help will be very appreciated. I attached my script file here for single (it does work) and multiple (it doesn't work) submission.
Many thanks
i'm not an expert in dyna but it looks like it is missing these 2 variables for licensing.
An example of usage is found here:
Hi Adriano,
I don't think so. As you can see in the file attached called "single" I already set up the env variables as:
/usr/lib64/openmpi/bin/mpirun -x LSTC_LICENSE_SERVER -x LSTC_LICENSE
It's just fine for single submission...
https://ph.engr.unr.edu/w/me/clusters/cfam/ls-dyna/?v=3
