🎉Community Raffle - Win $25
Join and Win
Reflect Meshed Surface
User: "Altair Forum User"
Altair Employee
Updated by Altair Forum User
Dear sir or madame,
I am currently trying to set up a simulation for our teams CFRP-rim.
In order to facilitate my meshing process, I trimmed the rim surface, so that only 60 degrees of the symmetrical surface were left. ( se attached picture1).  For my simulation I need the hole rim, so that I thought about reflecting the surface and mesh on planes defined by nodes of the surfaces side edges.
Finally, my problem is, that the mesh and surface reflect, but the original surface and mesh doesn't exist anymore.
I would be very thankful if you could help me with this issue
Thank you very much for your help
kind regards
1 - 2 of 21
    Altair Employee
    OP
    Hello,
    to keep the original mesh and surface, you have to make the 'duplicate' selection by clicking on the yellow entity selector field.
    <?xml version="1.0" encoding="UTF-8"?>post-250-0-39805200-1445417645_thumb.png
    <?xml version="1.0" encoding="UTF-8"?>post-250-0-68889100-1445417649_thumb.png
    This will keep your original mesh / surfaces, while only the duplicated selection will be reflected. Make sure that you choose the right component (current vs. original) when selecting. And merge the duplicate FE nodes by using the Tool - Edges - Equivalence function.
     Jan
    User: "Brian DO_21608"
    Altair Community Member
    Updated by Brian DO_21608
    Hello,
     Jan
    Hello,
    When i use reflect, translate ...command with duplicate elements option, i get error : after duplicate mesh, i get a new cad surface at the same position with mesh.
    So how to get duplicate mesh without create new surface in Hyperworks X 2022 ?
    Thank in advance
