User interface for Macros in FLUX
Hi!
How can I generate a tab in my macro user interface?
Example:
I have found this window type in the Overlay tutorial but I cannot find any hint in the python code.
In the Macro example is the code for a single window without tab element:
e.g.:
@param NPPoles R08 1 1 2 Number of pole pairs
@param NPPolesRep R08 1 1 0.5 Number of pole pairs represented in geometry (0.5 is only one pole represented)
@param StatorPeriodicity R08 1 1 2 Number of stator periodicities (different for NPPoles in fractional winding machines)
@param CurrentSupply CurrentSource 1 ? 1 Select the current sources corresponding to the stator supply (first is asssumed to be phase of reference)
@param Rotor MechanicalSetRotation1Axis 1 1 1 Rotor mechanical set
@param Stator MechanicalSetFixed 1 1 1 Stator mechanical set
def Find_Rotor_Angle_2D(NPPoles, NPPolesRep, StatorPeriodicity, CurrentSupply,Rotor,Stator):
Thank you very much.
Hi,
Unfortunately it is not possible to make a tab in the case of macros. it is a limitation.
Thank you.
Hi,
Thank you.
