Boundary Conditions & Constraints
Hello,
I am trying to run a Linear Static Analysis of a huge assembly. I have 4 ISO Corners at the bottom. I have 2d meshed it (Simplified Geometry : Quad4 Elements only). When i fix the bottom face only of all the four ISO corners and run my simulation i get unsatisfactory results. By unsatisfactory i mean significantly high stresses and displacements.
But when i create a RBE2 on each of the 4 individual ISO Corners (i.e 4 RBE2's) and apply constraint/SPC (All 6-DOFs FIXED) to those 4 RBE2s master node, i get satisfactory results. Could anyone explain why this contrasting results or mismatch?
Second approach with RBE2 fixed with all dof is recommended.Please request FEA ebook using below link.In page no 386 of ebook we talk about bracket analysis with and without rigid element.
Can you share the screenshot of both the cases(with RBE2 and without RBE2 )?
