1 - 7 of
71
Looks like the RBE3 independent nodes are connected to solid elements (which don't have rotational DoFs)
You can either edit the RBE3 and release the independent nodes DoFs in RBE3 panel>> Update
But HM should automatically take care of rbe3 Independent Dofs for solids.
Is it possible to share the model file?
Please use the file transfer link in my signature to share the model file
Hi,
Is there a reason for using RBE3?
Can you check with RBE2 instead?
