🎉Community Raffle - Win $25
Join and Win
Force Vector of Node Output
User: "Timo Ksr"
Altair Community Member
Updated by Timo Ksr
Hi everyone,
I would like to get a force vector (x,y,z) for a special node if possible.  I apply an enforced displacement to a node and then I need the forces at this node as output.
I tried somethiong with Global Output SPCF, but I dont know whether that is the right way to do it?
Thank you all!
Best regards,
Timo
1 - 2 of 21
    User: "Adriano_Koga"
    Altair Employee
    Updated by Adriano_Koga
    Yes. It is spcf results that you should request.
    You can request it in OPTI format or Punch for ascii output.
    Altair Employee
    Additionally if you need this for a particular node, you can request it for a SID (set id of type SET_GRID with the desired nodes).
    If you don't choose a set all nodes with spc or spcd will be written.
