🎉Community Raffle - Win $25
Join and Win
LS-DYNA composite shells to regular shells
User: "Razvan"
Altair Community Member
Updated by Razvan
How to convert
I have a shell meshed part (LS-Dyna profile) which has the thickness defined for each single element using 6 plies. The total thickness is the sum of the individual plies thicknesses. I want to convert the LS-DYNA'S  *ELEMENT_SHELL_COMPOSITE TO *ELEMENT_SHELL_THICKNESS in Hypermesh while maintaining the total thickness?
Is there any way to do this?
1 - 2 of 21
    User: "PaulAltair"
    Altair Employee
    Updated by PaulAltair
    Hi, not in core, it could be scripted, but it might be easier to script it in a text editor or excel if you are only doing it once. If you can't work out how to do it, but can share your *ELEMENT_SHELL_COMPOSITE cards from your .key file, I can do it for you, but I won't have time until Friday!
    User: "Razvan"
    OP
    Updated by Razvan
    Thank you Paul! I thought maybe I was missing something.
    This is a one time thing.. No script needed. I'll give it a shot using excel.
