🎉Community Raffle - Win $25
Join and Win
How to mesh plenty of elements in Hypermesh?
User: "Altair Forum User"
Altair Employee
Updated by Altair Forum User
Hello, All:
I built a REB2 in Hypermesh between two columns, and I need to build plenty of REB2 along the column height. As shown in the following figure, the green elements are REB2, I need to build REB2 at each node along the orange column (the space is the same along the column). So may I do something like array or copy for the REB2 I built in Hypermesh?
Thank you very much for your help.
1 - 4 of 41
    User: "tinh"
    Altair Community Member
    Updated by tinh
    Yes you can make copies by enter menu Tools>Transformation Tool
    if tow columns are 2d elems you can use panel 1d>linear 1d
    Altair Employee
    OP
    Hi, Tinh:
    Thank you very much, it works well. Just seem will take a long time since I have 1300 copies to generate.....
    May I ask how to check the REB2 direction. I know I can always create one REB2 or Update the REB2, but not sure how to check what's the direction of existing REB2. Thank you.
    User: "tinh"
    Updated by tinh
    Hi,
     you can check direction by clicking 'review' and select the rbe2
    Altair Employee
    OP
    Hi,
    Got it, works well.
    Thank you, Tinh.
