1 - 4 of
41
When I go to 3D-->Split-->refine element-->elem(all), it only refine the mesh on the surface part (second picture) and does not apply through the entire model. I need to split each element to two only along the 'y' direction. It means that instead of 8 elements in 'y' direction I need 16 elements.<?xml version="1.0" encoding="UTF-8"?>
Sorry for the late reply. Please refer below video from Simlab for changing layers.Also still i am not clear on your requirement.Please hide domain & handle for better understanding.
Let us know if simlab change layer functionality is similar to your requirement.
HM model? Screenshots? to better understand your question?
