Error generated by 2022.3 release when saving the antenna model in Gerber format
Froumsia Dokrom
Froumsia Dokrom Altair Community Member
edited October 2023 in Community Q&A
When I try to export my model in gerber format, there is a error message generated: "No valid include mesh(es) selected to export"as shown in the picture below.
Welcome!
Answers
  • Zeina
    Zeina
    Altair Employee
    edited October 2023
    Hi Froumsia,
    Please select "Simulation mesh" in the Mesh Exporter Tool dialog.
    You seem to have chosen "Model mesh" and you don't have one? as the error box states.
    Zeina
  • Froumsia Dokrom
    edited October 2023
    Zeina said:
    Hi Froumsia,
    Zeina
    Good morning Zeina.
    Thank you for your response. This is exactly what is happening. Now how do I export an antenna model to a Gerber file?
  • Zeina
    Zeina
    Altair Employee
    edited October 2023
    Hi,
    You can export a mesh in Gerber file format as you have tried to do. Please select, as I have mentioned in the previous reply, "Simulation Mesh" and then ok.
    There's nothing else you need to do.
    Best Regards,
    Zeina
  • Froumsia Dokrom
    edited October 2023
    Yes Zeina,
    I did as you said, but different message was displayed :"The format is not correctly supported for export".
  • Zeina
    Zeina
    Altair Employee
    edited October 2023
    Yes Zeina,
    I see, in that case can you please share the *.cfx?
  • Froumsia Dokrom
    edited October 2023
    Here attached the cfx file
  • Zeina
    Zeina
    Altair Employee
    edited October 2023
    Thank you for sharing Froumsia.
    It seems that the export to Gerber is only available using "Legacy CADFEKO". From your screenshot I see now that you are using the default CADFEKO which for the time being does not support this type of export.
    A workaround is to recreate your model using Legacy CADFEKO
    You can activate it from the Feko launcher:
    Then from the Home tab you can launch it  (the C in the icon shows in blue for Legacy):
    I hope this helps!
    Best Regards,
    Zeina
  • Froumsia Dokrom
    edited October 2023
    I hope this helps!
    Best Regards,
    Zeina
    Thank you so much. This is one of my greatest achievements of the day.
  • Zeina
    Zeina
    Altair Employee
    edited October 2023
    Glad it helped :)!
Welcome!
Welcome!
