Wrong thickness
Alessio Vanni
Alessio Vanni Altair Community Member
edited February 2022 in Community Q&A
Goodmorning everyone
I have a problem with the component thickness.
When I check the thickness of the elements I find a thickness of 5mm for all components unlike what is reported in the properties.
If I use the "by thickness" visualization, the thicknesses are correct, and the total weight of the model is correct. So the problem is for visualization only.
I would like to know if it ever happened to someone else and how to solve the problem.
Thank you
Welcome!
Answers
  • AltairLiz
    AltairLiz
    Altair Employee
    Thank you for your question.  Can you tell me which Altair product you are using so that I can move your question to the appropriate forum.
    Thanks,
    Liz Bleicher
    Community Specialist
  • AltairLiz
    AltairLiz
    Altair Employee
    Response from Alessio:
    Dear Liz,
    I am currently using Altair Hypermesh 2021.
    Best regards
    Alessio
  • Adriano_Koga
    Adriano_Koga
    Altair Employee
    it would be nice if you add a few pictures in here.
    Don't you have thickness directly assigned to your elements, maybe?
Welcome!
Welcome!
