Wrong thickness
Goodmorning everyone
I have a problem with the component thickness.
When I check the thickness of the elements I find a thickness of 5mm for all components unlike what is reported in the properties.
If I use the "by thickness" visualization, the thicknesses are correct, and the total weight of the model is correct. So the problem is for visualization only.
I would like to know if it ever happened to someone else and how to solve the problem.
Thank you
Thank you for your question. Can you tell me which Altair product you are using so that I can move your question to the appropriate forum.
Thanks,
Liz Bleicher
Community Specialist
