🎉Community Raffle - Win $25
Join and Win
Zero Plastic strain & Vonmises stress in EPS material
User: "Santhosh_22578"
New Altair Community Member
Updated by Santhosh_22578
Hi, I'm performing drop simulation on air conditioner with complete packaging. I modelled EPS (Expanded Polystyrene) material with crushable foam model. The run is being killed and showing error message ("Energy error limit reached"). When I checked the results of EPS material, it is undergoing very high deformation which is creating very high energy.
I have two questions.
1) How to avoid energy error ?
2) In EPS material, I'm observing zero plastic strain, VonMises stress even though it is undergoing high amount of deformation. What is the reason for this ?
1 - 1 of 11
    User: "Rogerio Nakano_21179"
    Updated by Rogerio Nakano_21179
    Hi
    Which material law are you using?
    Looking at the output file image, it seems you are adding a lot of mass .
    Are you using any time step control?
    Please check the young modulus of the material.
    And also the element formulation used. For foam, please try Isolid=11 .
    Regards
