No Closed Volume Found
User: "Altair Forum User"
Altair Employee
Updated by Altair Forum User
Hello, I'm still really new to Hypermesh, but I'm really having a difficult time with creating solids.  I'm using Hypermesh v12.  I created an iges file from solidworks to mesh and could not create a solid, so I went back and  created a simpler one.  I made a simple solid cube and imported it into hypermesh.  When I tried to create a solid in hypermesh, the program gave me the error 'No closed volume found.'  I've checked this forum and found one similar post which was not resolved.  I checked and I do not have any discontinuous edges.  I choose 'By 2D Topo' to see if there were any and the cube wireframe turns blue.  I apologize since I'm sure this a very newbie post, but at this point I'm not sure where else to ask about this.  I appreciate any help!
Edit: The uploader won't let me upload hypermesh binary files (.hm) as well as iges or sldasm files.  It says 'You aren't permitted to upload this kind of file.'  I've just uploaded some screenshots instead.
<?xml version="1.0" encoding="UTF-8"?>post-36158-0-20816700-1421868410_thumb.j
<?xml version="1.0" encoding="UTF-8"?>post-36158-0-18523000-1421868416_thumb.j
1 - 15 of 151
    Altair Employee
    OP
    If you could share your model, it's easier to help.
    Altair Employee
    OP
    Unfortunately, I am unable to upload my models since the uploader will not let me.  When I try to upload .hm, .igs or .sldasm files it says 'You aren't permitted to upload this kind of file.'  I uploaded a few pictures in my first post if that helps.  If you need more information, just let me know and I'll do what I can to get it for you.
    Altair Employee
    OP
    Hi Joey,
    Please use the dropbox link in the signature below to share the model.
    User: "Rahul_P1"
    Altair Employee
    Updated by Rahul_P1
    Joey,
    Please zip the model and upload the zipped file, or you can also change the extension to .jpg to upload and then tell us what you changed the extension from
    User: "Rahul_P1"
    Altair Employee
    Updated by Rahul_P1
    Joey,
    Also check if it is not a solid already, tool > count > solids
    Altair Employee
    OP
    Hello everyone, thank you for your comments, I really appreciate them.  I have included a link to a dropbox folder with the files which have been requested.  Rahul, I checked to see if they were already solids and they are, however, I need to create a new entity which has several solids under one name for the program I'll be exporting to.  So there are four entities which I have saved in the program and they are already solids, I need to add each of them to a new entity which I'll call 'Solid.'  However when I try to create a new solid, the program gives me the error I described earlier.
    https://www.dropbox.com/sh/j6rjvxu4794288t/AABHxG7BGVdlTtbiixs1tJwRa?dl=0
    User: "Rahul_P1"
    Altair Employee
    Updated by Rahul_P1
    Joey,
    by entity , do you mean collector?
    do you need to put your existing 4 solids into a collector called 'solid' ? to create collectors you just need to right click in the model browser are to the left > create > collector and then go to Geometry > organize > solids and choose the solids to move into the collector which you can right click and rename to solid.
    If you need to create actual solids in HyperMesh, you need a closed volume, i.e. a geometry of surfaces that is watertight, this will then be made into a solid using the solids > bounding surfaces option.
    Altair Employee
    OP
    Rahul, thank you for that information!  I did exactly what you told me and I was able to get it to work.  Thank you!
    Altair Employee
    OP
    Hello,
    Attached it  is my model. There are some assembly parts on it. I wanted to create solid but program says 'no close volumed volume find' . I tried to fix by your past solutions one by one. Still error is the same like ones.
    How can i fix this situation?
    Regards
    User: "QuyNguyenDai"
    Altair Community Member
    Updated by QuyNguyenDai
    I see only the screenshot of your model. So where's your model?
    User: "tinh"
    Updated by tinh
    Use auto cleanup, set parameter file so that you dont have to fix it one by one
    User: "Sanjay Nainani_20973"
    New Altair Community Member
    Updated by Sanjay Nainani_20973
    Hello,
    It seems that there maybe some more errors or open volume in your model. For better understanding please use the visualization panel to see at what places the geometry is open and then correct it.
    Set 'Geometry color mode' to 'By 2D topo' for better understanding.
    Thank you
    Altair Employee
    OP
    I looked at my geometry by using 'By 2D topo', one part of it showed with red lines. The other of it showed blue and green lines. What does it mean 'red' line ? How can i fix it?
    Thank you for your precious answer.
    Hello,
    'Red line' means that there is either a 'missing surface' along those edges or there are some 'connectivity issues' around those edges. Please check for these issues.
    'Blue line' means that the edge is suppressed and the 'Green line' means that it is shared. These are not the problem.
    To correct the 'Red lines' go to Geom>>Quick edit
    Here use the following options depending on the issue:
    1. Toggle Edge
    2. Filler Surface
    3. Replace Point
    Thankyou
    Altair Employee
    OP
    What a fantastic post! Thank very much!
