🎉Community Raffle - Win $25
Join and Win
Error #1000 on a contact
User: "LisaMontréal"
Altair Community Member
Updated by LisaMontréal
Hi,
I get an error when running my model:
 A fatal error has been detected during input processing:
  *** See next message about line 32654 from file:
      Z:/Bureau/Lisa/4) Altair - Modèle Pied Plat/Flatfoot_model_shell_trias_automesh_QI Optimized_v7
   'CONTACT       43     0.6      84      85    NORM0.0'
  *** ERROR # 1000 *** in the input data:
  Incorrect data in field # 7.
Obvioulsy it affects the contact whose ID is 43. It is a contact between 3D hexa elements et 2D trias elements.
Does anyone know what could be the problem on the contact ?
Thanks in advance for any help or idea to solve the issue,
Lisa.
1 - 2 of 21
    OP
    Is it because the SRCHDIS must not be equal to 0 ? Can anyone explain what is SRCHDIS exactly please ?
    User: "Rahul Rajan_21763"
    New Altair Community Member
    Updated by Rahul Rajan_21763
    Please refer attached screenshot from OptiStruct online help & specify the physical distance including shell thickness in the SRCHDIS field.
