Hello,
I am going through a Modal Frequency Response Analysis on a Crankshaft. The frequency range is 0 Hz - 1000 Hz for which I have used FREQi card image load collector. I have applied the load on the specific nodes of the crank pin using DAREA load type in the constraints panel. And I have also linked the load (with a table that I have created using TABLED1) using RLOAD2 card image load collector. And I have also input the frequency range i.e. 0 Hz as initial frequency, 1000 Hz as final frequency and 10 No. of mode shapes in EIGRL card image load collector. And finally, I created the loadstep for freq. resp. (modal) accordingly. But when I click on Optistruct Solver for results, an error #5408 occurs.
Messages for the job:
*** ERROR # 5408 ***
Aborting analysis because no structural modes have been
computed in the modal dynamic subcase 1.
*** PROGRAM STOPPED: FATAL ERROR(s) ENCOUNTERED.
How can I resolve this error and successfully achieve the results?
Thank You!
