Particle Representation Stream
1 - 1 of
11
Hi Leandro,
You need to reproduce the animation for the streamlines to show. Since they get generated based on the positions that the particles have in each time-step. So if you press play once you will be able to see them. Hope that this helps.
Kind regards
Ignacio
Hi Leandro,
Kind regards
Ignacio
