I am trying to create one (Only 1) meta particle in a factory But i keep getting this error message.
I have a factory that is 1000 by 1000 microns wide I want to create a meta particle at the location (10,0,0)micron whose particle diameter is 7.5micron and length is 1000micron
(I gave 0 as well as less separations and still it would not generate particles)
This is such a simple case..I can generate particles when i pick random positions. why does specifying the position not give me anything?
