🎉Community Raffle - Win $25
Join and Win
how excel file import to hyperview
User: "Altair Forum User"
Altair Employee
Updated by Altair Forum User
Hi
I have a excel sheet containing stress vs strain physical test data (over 120,000 points). Is it possible to import into hyperview to generate plot?
If not, what other tools can I use?
many thanks
1 - 3 of 31
    Altair Employee
    OP
    Hi,
    of course you can do it.
    I'm using normally Unicode *.txt file format ('save as' in Excel). Be sure that only the necessary datas are on the data sheet. (rows and columns)
    In Hyperview -> Hypergraph 2D you can choose this file and select your requests for x and y (use preview, it's a nice feature)
    Best regards,
    Mario
    PS: we have board section for hyperview ;-)
    User: "Sashi"
    Altair Community Member
    Updated by Sashi
    It's not very clear. I have saved my data in excel as unicode *.txt format. But while reading the data in hyperview it is showing en error.
    Thanks for clarification
    User: "Orestis_YB"
    Altair Employee
    Updated by Orestis_YB
    Hello Sashi,
    in order to plot these results in HyperGraph export your data in a csv format. Then you will be able to open the file and select X and Y components with no issue. Hope this helps!
    Best regards,
    Orestis.
