Hi all,
I have a variable which has some comp ids.
I need to diplay them as a tk table with some buttons .
The buttons has to be for some purposes.
can any one hlp with this.
Thanks,
Mahes
You can use tk table (refer to tk manual https://www.tcl.tk/man/
or hwtk::table (read usage in start>all program>altairhyperworks>tools>HWTK Gui Toolkit)
Thanks tinh.
invalid command name 'hwtk::demo::getpreviewframe' invalid command name 'hwtk::demo::getpreviewframe' while executing 'hwtk::demo::getpreviewframe' invoked from within 'set w [hwtk::demo::getpreviewframe]' (file 'D:/mahez/13Sep17/but.tcl' line 1) invoked from within 'source {D:/mahez/13Sep17/but.tcl}' ('uplevel' body line 1) invoked from within 'uplevel #0 'source {$file}'' (procedure '::HM_Framework::p_FileLoad' line 68) invoked from within '::HM_Framework::p_FileLoad 24' ('eval' body line 1) invoked from within '# Compiled -- no source code available error 'called a copy of a compiled script'' (procedure '::hwt::ReleaseCanvasButton' line 1) invoked from within '::hwt::ReleaseCanvasButton 0 ._Scripting.f35.button35' (command bound to event)
m getting above error ..y
Please show your but.tcl file
I just copied and pasted from that hw toolkit.
no changes
just to understand
package require hwat; set w [hwtk::demo::getpreviewframe]
catch {destroy .top} set w [hwtk::dialog .top] $w hide apply set recess [$w recess]
namespace eval ::texample {}
proc ::texample::OnSelect {W S c} { puts [info level 0] }
proc ::texample::OnOk {w T} { puts 'Selected items are --> [$T selectionget ]' $w unpost }
set sl [hwtk::selectlist $recess.sl -stripes 1 -selectmode multiple -selectcommand '::texample::OnSelect %W %S %c'] pack $sl -fill both -expand true $sl columnadd entities -text Entity $sl columnadd id -text ID $sl columnadd color -image palette-16.png $sl columnadd thickness -text Thickness
for {set i 0} {$i < 100} {incr i} { set clr [expr {int(rand()*64)}] $sl rowadd row$i -values
$w buttonconfigure ok -command '::texample::OnOk $w $recess.sl' $w post
The proc is defined in hwtk toolkit GUI, not in hypermesh. So it raises error when you run it in hm
hi tinh,
thanks .
I will find way to correct. /emoticons/default_smile.png' srcset='/emoticons/smile@2x.png 2x' title=':)' width='20' />
