Problem with *.t16 Marc results
Hello Everyone,
I have a very strange issue. I use HV for postprocessing results, and I use the MSC Marc 2014 for solving the model. Reading results from MSC Marc (t16 file) in the HV usually goes smooth (sometimes not all elements are visible ). Today I have prepared a co-simulation between Adams (Multibody model) and Marc (flexible nonlinear part). As a result from that simulation I get one results file for MSC Adams model, and one for MSC Marc model (*.t16). Using Marc Mentat I am able to post-process that t16 file, but while I am trying to import it to the HV, I get a message: 'Failed to attach results' and I can only see the model, but without results. This occur only with t16 results file from co-simulation.
Do you have any idea about this issue?
Kind Regards,
Paweł
AGH University of Science and Technology, Kraków, Poland
I have tried the HW 12 and 2017. I believe that the analysis is complete, because it produce Exit number 3004, this is a successful completion to a Marc simulation. Attached are marc files. Thank you for your interest.
Kind Regards, Paweł
Hi Pawel,
Ensure that the result file is complete that is the run is not stopped in the middle. Which HyperWorks version are you using?.
If possible, please share the file so that we can also check the same from our end.
