Hello there,
I am trying to model the gasket in an engine using MGASK. The contact between gasket and cylinder head should be set to Slide. However only freeze contact works. The slide or stick contacts does not converge. I tried Cntstab, ExpertNL, set NIN to 10, increased convergence criteria. None of them works. any comment on this issue would be appreciated.
Thank you in advance !
