Altair RISE
Nominate Yourself Now!
verifying existing activation code
User: "Bruce_22050"
New Altair Community Member
Updated by Bruce_22050
Hi,
Several people on my team are using v14 Monarch to create models for report mining. We have a list of activation codes. I want to reconcile that list against each developers PC. Is there an easy way to have each developer verify which code they are using ? Please advise and thanks in advance.
Cheers,
Bruce McHendry
1 - 2 of 21
    User: "Altair Forum User"
    Altair Employee
    Updated by Altair Forum User
    I'll preface this reply by suggesting you might want to talk to Support to see if there is a better way for your purpose - depending on how many Licenses are involved ....
    But so far as I can see the only way of discovering per machine the specific Activation Code used is to head into the Deactivation routine using the License Manager until that code is presented on screen. Then cancel the process to leave things unchanged.
    http://docs.datawatch.com/monarch/install/Monarch_Install_Guide.pdf#page=50
    The link may help. It refers to V15 but as far as I know V14 is the same. You may want to read a few of the other pages around the linked page for the full comfort factor.
    I'm assuming no one has a list of which activation code was used for which machine ... ? Hence why you need one now?
    HTH.
    Grant
    Altair Employee
    Thanks Grant ! The method you described worked perfectly. We had 2 codes in our "pool" and 2 people ran installs but neither could remember which one they used. We had a chat and think they realise they need to keep track now. Thanks again !
    Cheers
