Defining arbitrary Geometry as Rigid Body
Hello @ all
I'm new at Hyperworks and so i started my earning of experiences with the tutorials and Guides. Now i've set up a small modell to simulate many basic features i need to know for my further work. I choose the drawing process of a wire through a die. (see pic.)
The topic i'm interested in is - How could I define my die (green structure) or a arbitrary geometry as a rigid body?
I've looked at some guides/tutorials and forum discussions but i don't find the right solution. I find the set up of predefined rigid structures (plane, tube, sphere) in /RWALL but these don't match my geometry.
Simulation parameters:
Model set up in Optistruct (GUI)
wire (red) : mat=st(MAT1+MATS with plastic, H and Limit), nlgeom, drawing defined as a motion/displacement of the left surface through the die (TABLED1, SPCD and NLOAD1)
die (green): mat=should be rigid ;-) with no displacement and no deformation (should stick on it's place during simulation)
I'm only interested in the deformation and drawing force of the wire.
I hope someone can help ;-)
Thanks Alex
Do you know how OptiStruct set the rigid body?
I want to use rigid body to compare with my RBE2 in same model.
Hi,
what problem you are facing in current approach using Optistruct solver.Even you can give a try with Radioss solver assuming die as Rbody and give imposed displacement to wire.
Regards
Rahul R
