Increase memory allocation for HyperMesh
Hi,
I have a problem with HyperMesh.
It uses only 900 Mo of my RAM (and can't go further) while it would be useful to use more for some operations.
So, I would like to increase this limit level. Do you have any ideas to do that ?
Thank you !
Regards,
Cya.
Hi,
Thanks for your answer.
You say 'Radioss/optistruct' options, but it works for HyperMesh operations anyway ?
'Radioss/optistruct' memory options are for SOLVER, not for your Hypermesh session.
IMHO, Hypermesh uses memory automatically when needed. You say your Hypermesh uses ONLY 900MB? Maybe your model needs only that quantity of memory? How about your model size? Do you try any bigger model yet ?
Sometimes, my Hypermesh's session uses some Go of memory (overs my 20Go physical memory).
16GB of ram is NOT small at all for a workstation. If your Hypermesh is slow, I think RAM is not the cause.
What about your graphical card ? Your OS ?
Hi Mechanist,
What is the version of HyperWorks you are using?
May be you can check if the graphics drivers are up-to-date...
I have the same trouble with you in serveral days ago, but now it is solved in easy way.
Go to start>adjust the appearance and performance of windows>advanced>change
untick automatically manage paging file size for all drives
in custom size keep initial size greater than 1.5 times and maximum size 3 times of your RAM size and click set
ex. if 4 gb ram allocate 7000-14000 Mb
hope this will solve your problem
let me know if this works for you also
Hi cya,
Go to > Analysis >Radioss/optistruct > Memory options
here change it from'memory default'to required value (the maximum value depends on your RAM size)
