🎉Community Raffle - Win $25
Join and Win
Increase memory allocation for HyperMesh
User: "Altair Forum User"
Altair Employee
Updated by Altair Forum User
Hi,
I have a problem with HyperMesh.
It uses only 900 Mo of my RAM (and can't go further) while it would be useful to use more for some operations.
So, I would like to increase this limit level. Do you have any ideas to do that ?
Thank you !
Regards,
Cya.
1 - 13 of 131
    Altair Employee
    OP
    Hi cya,
    Go to > Analysis >Radioss/optistruct > Memory options
    here change it from'memory default'to required value (the maximum value depends on your RAM size)
    Altair Employee
    OP
    Hi,
    Thanks for your answer.
    You say 'Radioss/optistruct' options, but it works for HyperMesh operations anyway ?
    Altair Employee
    OP
    'Radioss/optistruct' memory options are for SOLVER, not for your Hypermesh session.
    IMHO, Hypermesh uses memory automatically when needed. You say your Hypermesh uses ONLY 900MB? Maybe your model needs only that quantity of memory? How about your model size? Do you try any bigger model yet ?
    Sometimes, my Hypermesh's session uses some Go of memory (overs my 20Go physical memory).
    User: "Mechanist"
    Altair Community Member
    Updated by Mechanist
    Hello Friends,
    I have same problem. My ram is 16 GB. But Hypermesh is working very slowly for small models.  Can you help me?
    Thank you in advance
    Altair Employee
    OP
    16GB of ram is NOT small at all for a workstation. If your Hypermesh is slow, I think RAM is not the cause.
    What about your graphical card ? Your OS ?
    User: "Mechanist"
    My PC properties are windows 8.1, Intel® Core™ i7-5700HQ 4-Cores,  2GB GDDR5 nVIDIA® GeForce® GTX960M 128-Bit DX12. And my installation disc is 256GB SSD
    User: "Mechanist"
    UP
    Altair Employee
    OP
    Hi Mechanist,
    What is the version of HyperWorks you are using?
    May be you can check if the graphics drivers are up-to-date...
    Altair Employee
    OP
    I have the same trouble with you in serveral days ago, but now it is solved in easy way.
    User: "Mechanist"
    Hello korence,
    How did you solve this problem? Could you please explain me?
    User: "Wiz211"
    Updated by Wiz211
    I think in analysis options you can add '-core in' to force HyperMesh to allocate more Ram for the analysis
    Altair Employee
    OP
    could you send some photos? I have the same problem
    Altair Employee
    OP
    Go to start>adjust the appearance and performance of windows>advanced>change
    untick automatically manage paging file size for all drives
    in custom size keep initial size greater than 1.5 times and maximum size 3 times of your RAM size and click set
    ex. if 4 gb ram allocate 7000-14000 Mb
    hope this will solve your problem
    let me know if this works for you also
