Altair RISE
Nominate Yourself Now!
Reading Grid Point Stress Data using Tcl
User: "Girish2121"
Altair Community Member
Updated by Girish2121
Hello everyone,
I am new to Tcl . I am interested in reading the result file(H3D FILE)  i.e read Grid Point Stress Data of particular node ids .
What commands should be using ?Please reply if you have  tried this before!!
1 - 9 of 91
    User: "tinh"
    Updated by tinh
    hi,
    you can file relevant commands in hyperworks destop reference guide
    <?xml version="1.0" encoding="UTF-8"?>post-3195-0-37989400-1446299020_thumb.pn
    User: "Girish2121"
    OP
    Thanks Tinh,
    I got off to to a start with help of Hyperworks help !!.
    I was looking for any particular tutorial where results are extracted from the model .I am stuck with the Hyperview Hierarchy  sequence !!
    User: "tinh"
    Updated by tinh
    Hi
    Try looking in hw scripts exchange
    User: "Girish2121"
    OP
    Hello Tinh,
     Coming back to forum after couple of months!!
    I am facing difficulty using the SetDataType command in the ContourCtrl  class of Hyperview
    Though I can set the query to Displacement, Grid Point Stresses(Prop 1),etc but I am not able to  choose  sub options like  Mag,X,Y,Z and Von Mises ,Signed VonMises, respectively.How do I do it ?
    Your help is very much appreciated !!
    Thanks and Regards,
    Girish
    User: "tinh"
    Updated by tinh
    Hi,
    use SetDataComponent command
    User: "Girish2121"
    OP
    Yes it works !!
    With respect to the Hyperview help on Tcl/TK Classes , the description on SetDataComponent is a bit misleading. It says the options can be either node,line,shell or solid.
    Can  you elaborate  on the following classes(with significance to displaying a contour plot) :
    1. SetDataComponent
    2.SetShellLayer
    3. SetDimensionEnabled
    User: "tinh"
    Updated by tinh
    Yes, hw help has some mistake while explaining functions
    I do not ever use above functions, I just guess.
    so SetDataComponent => will set component of DataType, example: DataType=Displacement, DataComponent=X
    it's better for you to try some values, and then look for any affect
    User: "Girish2121"
    OP
    Hello tinh,
    Greetings !!
          I intend to read  all the labels of the entity sets available in a HyperView Model file. How should I do it ?
    I tried using GetSelectionSetHandle command, but it requires that I get the handle for each set then read the label .
    Something similar to GetSelectionSetList  will be helpful or any other method ?
    Regards,
    Girish
    User: "tinh"
    Updated by tinh
    Yes, do a loop through all sets, get handle and label of each one and append it to a list
    finally print this list of all labels
