excitation by acceleration Freq resp(modal)
User: "VAL1"
Altair Community Member
Updated by VAL1
I'd like to add excitation by acceleration in Freq resp(modal).
I had below error. how should I do?
(I add DAREA in constraint)
*** ERROR # 2094 ***
  EXCITEID on RLOAD2 # 6 data references follower force or nonexistent
  SPCD # 8.
1 - 13 of 131
    User: "VAL1"
    OP
    Updated by VAL1
    I have another question, I want to add 35G (343 m/s/s).
    But I use the unit (ton, mm, MPa) in the model.
    So Should I input 343000 mm/s/s ?
    User: "Rahul Rajan_21763"
    New Altair Community Member
    Updated by Rahul Rajan_21763
    Use SPCD card instead of DAREA.Whenever load is in the form of acceleration ,velocity and displacement ,we have to use SPCD card.
    Download free eBook on Dynamic analysis using OptiStruct.
    https://altairuniversity.com/free-ebook-learn-dynamic-analysis-with-altair-optistruct/
    In chapter 14 ,example 14.2 and 14.3 we have applied load as acceleration.
    User: "VAL1"
    OP
    Updated by VAL1
    Thank you Rahul san
    How should I do about inputting unit?
    User: "Altair Forum User"
    Altair Employee
    Updated by Altair Forum User
    your units are quite right.
    User: "VAL1"
    OP
    Updated by VAL1
    Thank you Mrt san,
    I'd like to confirm the SPCD value.
    Can I check the value of SPCD after setting or reopening file?
    Altair Employee
    Yes, Either you can check the same by opening the fem file in any text pad or review from constraint panel.
    User: "VAL1"
    OP
    Updated by VAL1
    Thank you Prakash san.
    User: "Mahantesh"
    Updated by Mahantesh
    Hello Sir,
                      I am facing same error but you were mentioning to assign SPCD card but we were unable to assign the card.. hence please helps to solve this issue
    Thanks and Regards
    Mahantesh
    User: "Mahantesh"
    Hello Sir,
                     I need some tutorials regarding the  FRF Analysis So kindly help me to get the tutorials
    Thanks and Regards
    Mahantesh
    Please download free eBook on Dynamic analysis using OptiStruct.You will find relevant tutorial and examples.
    User: "Mahantesh"
    Thanks Rahul for your quick response
    User: "Mahantesh"
    Hello Rahul,
                             Those tutorials are not supporting in 14.0 version and those belongs to 17.0 version so kindly send me the 14.0 version tutorial and if it possible send me to the below mail id mahantesh.mvj@gmail.com
    Thanks and Regards
    Mahantesh
    14.0 is very old version and upgrading to new version would help you to use new features of OptiStruct.
