Altair RISE
Nominate Yourself Now!
Transient Magnetic Simulation of a PMSM doesn't get solved
User: "pcolgon"
Altair Community Member
Updated by pcolgon
Hello,
I'm currently analyzing a PMSM in the transient magnetic application mode. So far the geometry and the physics seem fine (the physics check gives me just a warning about "Loss properties suitable only for laminated regions". Apart from that everything works. The solving process also starts but in the second solving step, for time and also for example changing the rotor position, the process stops and gives me the following error report:
OR_R_AFFIT => No entity OR_PAR_{ENT}_I exists
OCRCAS   => Number RB.F3D.OR_PAR_ICCG_I(0) out of bounds
OCRCAS   => CASE getting aborted
OR_R_AFFIT => failed
BPR_BRSYST => failed
Solution of linear system by SICCG impossible
The solving process has probably not correctly converged
Does anyone know what that means and maybe can help me?
Thanks in advance
