🎉Community Raffle - Win $25
Join and Win
CFD HyperMesh Analysis can't lunch
User: "Hristijan Mazganski"
Altair Community Member
Updated by Hristijan Mazganski
Hi. I am new to cfd analysis, so i follow the tutorial for running the CFD of simple Venturi-pipe, at first run when i have a lot of mistakes in parameters assign the simulation runs oky and the results were not as I expect, so I've adapt the model second time(like in tutorial), i  try to lunch the analysis and they wont start, so i try several times but every single time is the same, except the firs time :D
1 - 1 of 11
    User: "Adriano Koga_20259"
    New Altair Community Member
    Updated by Adriano Koga_20259
    Hi,
    when you have any issue or error, it is always good to share some prints of your error messages or the .log files from AcuSolve so people can take a look.
    You can attach them, or copy the rrror messages here.
