AMan fails to write .ffe file to my disk
I'm currently trying to use the Antenna Array Tool in AMan. After I click "OK" in the dialogue, I am prompted to give the file name and location for the resulting .ffe file. But after I input the name and location and click the "save" button, I cannot find the resulting .ffe file in that location (It seems the file is not written to that location). So I wonder if this is a problem with my operating system or a bug of AMan?
Hi Kk,
I tried to reproduce this on my machine with v.2022.3.2 but the *.ffe was created successfully for different locations I tested.
Each time AMan confirms the creation of the file by prompting the following dialog:Can you try creating the file in another directory on your machine and make sure it is not a read only directory?
Best Regards,
Zeina
Hi Zeina,
Thanks for your reply. When I generate the *.ffe file, my AMan does not prompt this dialog. I have tried many locations, but none of them work.
I'm currently using the student edition. I also noticed that there is a similar Question in the forum (please see the following link), and the poster uses the student edition as well. Is this one of the limitations of the student edition?
Link: Saving Generating Beams and Envelope Pattern .ffe - WinProp - Altair Products - Altair Community
Best regards,
Kk
Hi Zeina,
Best regards,
Kk
Hi,
Thank you for the information. I do not see this limitation for the student edition. I will double check and get back to you.
Best Regards,
Zeina
Hi,
Thank you for the information. I do not see this limitation for the student edition. I will double check and get back to you.Best Regards,
Zeina
Hi Zeina,
I just tried this operation on another PC with the student edition, and it has the same problem. I guess it may be a bug or limitation of the student edition.
Best,
Kk
Hi Kk,
Best Regards,
Zeina
