🎉Community Raffle - Win $25
Join and Win
Thermal Stress Analysis on a Engine Block (
User: "SAI VIJAY CHANDRA GAJULA"
Altair Community Member
Updated by SAI VIJAY CHANDRA GAJULA
CAN YOU PLEASE EXPLAIN IN DETAIL WHY IM GETTING THIS ERROR
1 - 3 of 31
    User: "Adriano_Koga"
    Altair Employee
    Accepted Answer
    Updated by Adriano_Koga
    Hi,
    ERROR # 70
    i believe the error message says it clearly that you are running some thermal stress analysis in your model, and you have not provided the thermal expansion coefficients (alpha / A) in your material card.
    As you want to compute thermal stresses, these will be generated from thermal loads, and these loads will cause your parts to expand or shrink due to thermal expansion effects. Thus it is mandatory that you define thermal expansion coefficients.
    OP
    how to create entity sets for conduction for this component
    Altair Employee
    go to your Help >> OptiStruct >> Tutorials
