Thermal Stress Analysis on a Engine Block (
SAI VIJAY CHANDRA GAJULA
SAI VIJAY CHANDRA GAJULA Altair Community Member
edited June 2021 in Community Q&A
CAN YOU PLEASE EXPLAIN IN DETAIL WHY IM GETTING THIS ERROR
Welcome!
Best Answer
  • Adriano_Koga
    Adriano_Koga
    Altair Employee
    edited June 2021 Answer ✓
    Hi,
    ERROR # 70
    i believe the error message says it clearly that you are running some thermal stress analysis in your model, and you have not provided the thermal expansion coefficients (alpha / A) in your material card.
    As you want to compute thermal stresses, these will be generated from thermal loads, and these loads will cause your parts to expand or shrink due to thermal expansion effects. Thus it is mandatory that you define thermal expansion coefficients.
Answers
  • Adriano_Koga
    Adriano_Koga
    Altair Employee
    Hi,
    ERROR # 70
  • SAI VIJAY CHANDRA GAJULA
    edited June 2021
    how to create entity sets for conduction for this component
  • Adriano_Koga
    Adriano_Koga
    Altair Employee
    edited June 2021
    go to your Help >> OptiStruct >> Tutorials
Welcome!
Welcome!
