🎉Community Raffle - Win $25
Join and Win
Deleting a Variable / Application Error
User: "mkress"
New Altair Community Member
Updated by mkress
Hey guys,
I'm looking for a command to close or delete a variable totally. I got the problem that when I'm trying to run my script for the second time this error is occuring:
This is the file in which the error is occuring:
Before starting this script the sample.scv file is created in this file:
I guess the variable is still saved somewhere in hypermesh and thus it can be deleted totally. I'm looking forward to your ideas.
Kind regards
Michael
1 - 8 of 81
    User: "tinh"
    Updated by tinh
    What is the variable?
    Why do you need to delete it?
    User: "mkress"
    OP
    Updated by mkress
    Hello thin, thank you for your reply,
    the variable is a .csv file which i created with the script ' '. After that i would like to open the file with the script ' --> '. Both scripts starts with a button in the utility menu.
    Is it possible that the error related to the memory of Hypermesh? Perhaps the scripts are still running?
    I want to close the script ' temp_in_fem.tcl ' with the command 'exit' at the end of the script. Perhaps i should use an other command?
    Kind regards
    Michael
    User: "tinh"
    Updated by tinh
    No
    The error is very obvious that file sample.csv is not found because $path =''
    Please post your code here
    I cannot open tcl file
    User: "Altair Forum User"
    Altair Employee
    Updated by Altair Forum User
    Hey tinh,
    here is the codes you asked for:
    set path ''
        set name ''
        set temp ''
    set infor ''
    set infor [open C:/Users/Simon/Documents/path.txt r]
        #Startinformationen einlesen
        while {[gets $infor line]!=-1} {
        #Variable zeilenweise auslesen
            incr z
        #Zeilenzahl
                if {$z==1} {set path $line}
                if {$z==2} {set temp $line}
                if {$z==3} {set name $line}
        #Informationen der Zeile 1+2 in Variable schreiben
        #Programmteil 2: Umrechnung der Knotenspannung
        set data ''
        set data [open $path/sample.csv r]
        #Knotenspannung einlesen
            while {[gets $data lines] >=0} {
        #Loop für jede Zeile
                if {$lines==''} {break}
        #Wenn Zeile leer ist, abbruch
                    incr i
        #Loopzähler
                        if {$i>=1} {
        #Ab Zeile 2 in Variable schreiben
                            set fields [split $lines ',']
                            lassign $fields field1 field2
        #Zeile an Komma trennen, die zwei erstellten Werte in Variablen schreiben
                                if {![regexp {N/A} $field2]}     {
        #Wenn in Feld 2 {N/A} steht wird die Zeile nicht in Variable geschrieben
                                    if {$field2>=$temp} {
        #Nur wenn Spannung größer als Referenztemperatur, einschreiben
                                    set dif_temp [expr $field2 - $temp]
        #Temperatur differenz berechnen
                    set a 'TEMP'
                    set b 3
        #Parameter die zusätzlich eingeschrieben werden
                    set formatStr {%0s%12s%8s%8s}
        #Zeichenabstand der Variablen definieren (1s = ein Lehrzeichen)
                    append xxx '[format $formatStr $a $b $field1 [format '%.1f' $dif_temp]]\n'
        #write everything in a variable
                close $data
        #Programmteil 3: Suchen der Einfügezeile in der .fem Datei
            set fp ''
            set fp [open $path/$name r]
            set fem_file [read $fp]
            close $fp
        #öffnen der .fem Datei
                set a 0
                set b 0
                set e 0
        #setze Variablen =0
                    set daten [split $fem_file '\n']
                    foreach line_pos $daten {
        #loop, jede Zeile abfragen
                    if {![regexp {SPC} $line_pos] || ![regexp {1} $line_pos]} {incr a} else {set b $a}
                    if {[regexp {SPC} $line_pos] && [regexp {1} $line_pos]} {incr e}
        #Logik, für das Finden der individuelle Einfügezeile
                    set num ''
                    set num [expr $b + $e +1]
        #Zeilennummer
        #Programmteil 4: Einschreiben in die .fem Datei
            set daten ''
            set daten [open $path/$name r]
                set y 0
        #Setze Variable 0
                    while {[gets $daten zeile] >=0} {
        #Loop einlesen
                        incr y
        #Loopzähler
                            if {$y<=100} {
                                    append zzz '$zeile\n'
        #.fem Datei bis Zeile 100 in Variable schreiben
                                if {$y==$num} {
                                    append zzz '$xxx\n'
        #Temperaturen in Variable schreiben
                            if {$y>100} {
        #.fem Datei ab Zeile 101 in Variable schreiben
                                if {![regexp {TEMP} $zeile] || ![regexp {3} $zeile]} {
        #wenn bereits Temperaturen in der .fem Datei stehen, diese nicht in die Variable schreiben
        #einschreiben der .fem Zeilen
        #Programmteil 5: Outfile erzeugen / Programm schließen
            set outfile [open $path/$name w]
            puts $outfile $zzz
            close $outfile
        #outfile erzeugen und Variable einfügen
            catch {unset temp outfile}
        #zur sicherheit ????????
            exit
        #Programm schließen
    Kind regards,
    Simon
    User: "tinh"
    Updated by tinh
    $path depends on file 'C:/Users/Simon/Documents/path.txt'
    please post its content here
    Altair Employee
    This is the content of the path.txt:
    C:/Users/Simon/Desktop/Test_1
    110
    abc.fem
    User: "tinh"
    Updated by tinh
    You have to set z = 0 before the loop 'while'
    Altair Employee
    Great, the program is finally working!
