🎉Community Raffle - Win $25
Join and Win
Element quality check between nastran and optistruct
User: "gopal_rathore"
Altair Community Member
Updated by gopal_rathore
Hi,
I am having a Nastran solver deck and want to run it on optistruct solver. When I see element quality criteria in Nastran , it shows max. as 0.008 but the same in Nastran shows 51.55
How these values can interpreted as both decks solvers showing different values.
Any methodology to understand this
Thank you
1 - 13 of 131
    User: "QuyNguyenDai"
    Updated by QuyNguyenDai
    Which criteria???
    OP
    Warpage, min. and max. angles of tria and qaud element
    User: "Altair Forum User"
    Altair Employee
    Updated by Altair Forum User
    I am sorry, in Nastran it shows as 0.008 and in HM with OptiStruct profile it shows as 51.55, is that correct??
    OP
    Yes,
    This is the same thing it shows.
    OP
    Hi,
    Any update on this
    Altair Employee
    Hi Gopal,
    I will check with experts about this.
    Altair Employee
    Hi Gopal,
    Can you let me know which criteria are you looking at?
    You have given numbers of 0.008 and 51.5, which quality parameter is it for?
    Altair Employee
    You can refer this on how element quality is calculated.
    OP
    Hi Gopal,
    Hi,
    This is for warpage
    OP
    Hi,
    Anything on above points
    Altair Employee
    Hi Gopal.
    Can you share a sample model with difference in warpage between Nastran and OptiStruct?
    OP
    Hi,
    There is one tool in 17 version in Hyperview> Preferences>NVH utilities to understand the identification of global and local modes. It talks about setting a criteria based on percentage range for identification. I wanted to know how it is setting up this criteria
    I have attached image for reference
    OP
    Hi,
    Sorry, this content is wrongly posted.
