Solution time increases rapidly
RAMGANESH
RAMGANESH Altair Community Member
edited October 2020 in Community Q&A
Dear All,
I had run my analysis in radioss and it shows remaining time nearly 22k secs. then i left it idle to solve and the system gets to sleep mode when again i started the system the solution time remaining is suddenly increases rapidly from 13k sec to 55k sec and it solves . kindly give your suggestions.
Thanks
Welcome!
Answers
  • Altair Forum User
    Altair Forum User
    Altair Employee
    edited May 2016
    What type of analysis you are doing?. Seems like the timestep goes down...is it an impact problem?
  • RAMGANESH
    edited May 2016
    Dear Sir,
    yes it is an impact test,
    Thanks
  • Altair Forum User
    Altair Forum User
    Altair Employee
    edited May 2016
    Please check your contacts, check Gapmin ( Minimum gap for impact activation)
    Can you share _.0001.out file
Welcome!
Welcome!
