CFAILURE in PCOMPP
Hy there,
i want to create an Output of Composite failure criteria for my model. I tried this according to the following topic:
But i can't find the 'CFAILURE' Output request Option in the 'OUTPUT' Card.
I am using PCOMPP as Property, might this cause the problem?
Thanks for your help,
Andreas Kießkalt
Hy,
first of all thanks for your answer!
Unfortunatelly i can't find Control Cards >> Global Output Request >> CFAILURE (see the screenshot)
Am i doing something wrong?
Thanks in advance,
Andreas Kießkalt
Which version of HyperWorks are you using?
HyperWorks versions prior to 14.0 doesn't have this feature to include CFAILURE through gui. It has to be included in solver file manually.
Hy,
i am using HyperWorks v11.0.
How can i insert it manually? Is there any kind of manual oder tutorial?
Thank you,
Andreas Kießkalt
Hy again,
now i can choose the result type 'Composite Failure Index(s)' but if i look at the contour plot, all elements have the value zero.
Can you imagine what is my mistake?
Thanks in advance,
Andreas Kießkalt
Hy again,
Hi,
Can you share the model file?
Hy,
please see the attached model file. It would be great if you can help me!
Thanks in advance,
Andreas Kießkalt
Hi,
Make sure you select desired failure theory in PCOMPP property card. I see that's missing.
Hy,
thanks a lot, now it works! /emoticons/default_smile.png' srcset='/emoticons/smile@2x.png 2x' title=':)' width='20' />
Best wishes,
Andreas Kießkalt
Hi Andreas Kießkalt,
Go to Control Cards>> Global output Request>> CFAILURE and use the same to output failure parameters.
