🎉Community Raffle - Win $25
Join and Win
CFAILURE in PCOMPP
User: "Altair Forum User"
Altair Employee
Updated by Altair Forum User
Hy there,
i want to create an Output of Composite failure criteria for my model. I tried this according to the following topic:
But i can't find the 'CFAILURE' Output request Option in the 'OUTPUT' Card.
I am using PCOMPP as Property, might this cause the problem?
Thanks for your help,
Andreas Kießkalt
1 - 9 of 91
    Altair Employee
    OP
    Hi Andreas Kießkalt,
    Go to Control Cards>> Global output Request>> CFAILURE and use the same to output failure parameters.
    Altair Employee
    OP
    Hy,
    first of all thanks for your answer!
    Unfortunatelly i can't find Control Cards >> Global Output Request >> CFAILURE (see the screenshot)
    <?xml version="1.0" encoding="UTF-8"?>hyperworks_global_output_request.thumb.png.2d6bc949f04484ba8a391a62f6c8eb28.png
    Am i doing something wrong?
    Thanks in advance,
    Andreas Kießkalt
    Altair Employee
    OP
    @kiesskalt
    Which version of HyperWorks are you using?
    HyperWorks versions prior to 14.0 doesn't have this feature to include CFAILURE through gui. It has to be included in solver file manually.
    Altair Employee
    OP
    Hy,
    i am using HyperWorks v11.0.
    How can i insert it manually? Is there any kind of manual oder tutorial?
    Thank you,
    Andreas Kießkalt
    Altair Employee
    OP
    Hy again,
    now i can choose the result type 'Composite Failure Index(s)' but if i look at the contour plot, all elements have the value zero.
    Can you imagine what is my mistake?
    Thanks in advance,
    Andreas Kießkalt
    Altair Employee
    OP
    Hy again,
    Hi,
    Can you share the model file?
    Altair Employee
    OP
    Hy,
    please see the attached model file. It would be great if you can help me!
    Thanks in advance,
    Andreas Kießkalt
    Altair Employee
    OP
    Hi,
    Make sure you select desired failure theory in PCOMPP property card. I see that's missing.
    Altair Employee
    OP
    Hy,
    thanks a lot, now it works! :)/emoticons/default_smile.png' srcset='/emoticons/smile@2x.png 2x' title=':)' width='20' />
    Best wishes,
    Andreas Kießkalt
