Problem with translating a sphere
Updated by Altair Forum User
So I created two spheres following the procedure on the attached document, reason for two spheres was to use the subtraction feature in tools to make the sphere hollow, i.e. empty sphere rather than a solid one. The problems I am having is that one face remain when I try to vertically translate the sphere, and I get a mesh error when I finally manage to make that face disappear. I have attached a screenshot with the error I am getting, the document used to draw the spheres and also my model simulations. Please help me.
1 - 1 of
11
Hello,
In your case you need to change the dimension of your infinite box because the volume 6 of infinite box is in contact with the sphere. I changed the infinite box dimension (I put 340 instead 300 and 380 instead 350), I reached to mesh the project.
Best regards.
