Altair RISE
Nominate Yourself Now!
RBE Node Selection
User: "Nikolai"
Altair Community Member
Updated by Nikolai
Hello,
I would like to create a RBE between a node in a center of a hole and the surrounding nodes. However I do NOT want to select nodes on the bore wall which is often done because it's easy to select these nodes 'by face' (Attachment left picture). I would like to select nodes in the plane of the center node with a specified radius  (Attachment right picture). Is there any script available? Is there any quick manual way? Only way I could think of is to create a circle geometry around the center node and select nodes by geometry and using the created circle.
Hope anyone can help.
Thank you in advance.
1 - 2 of 21
    User: "tinh"
    Updated by tinh
    I think it is a profesional way!
    User: "Simon Križnik"
    Updated by Simon Križnik
    Hi,
    another option would be to isolate with spherical clipping (Display toolbar)
    https://player.vimeo.com/video/33707305
    EDIT: Never mind, just realized I misunderstood your query.
