🎉Community Raffle - Win $25
Join and Win
discrete material optimization / multi material optimization
User: "Altair Forum User"
Altair Employee
Updated by Altair Forum User
Hi all,
is there a way to do a topology optimization where the solver can choose from given materials (eg. Material A(stiff) or B(elastic)) instead of changing the density of ONE material?. I have read in papers about 'discrete material optimization' or 'multi material optimization' where exactly this is done. Is this supported in Optistruct?
regards
Michael
1 - 3 of 31
    Altair Employee
    OP
    Hi Michael8,
    You can optimize the material parameters in Size optimization.
    Topology optimization is more concentrated on material density distribution.
    Altair Employee
    OP
    I have tried to do that. in the generic relationship i selected by material, and can then choose my 'basic material' and the parameter i want to change (in my case the Shear modulus G). Then i seleced my design variable (using DDVL discrete values).
    This was done for each 'zone' of my part that i want to optimize. and a new property for each zone with the respective basic material of the zone.
    but somehow nothing was done in the optimization (i defined everything.. responses, objective, constraints, variables, ...)
    I use solid elements -- is that maybe the problem? that sizing optimization only works for 1d and 2d elements at the moment?...
    regards.
    Altair Employee
    OP
    Hi,
    Yes, try with 2D elements.
