🎉Community Raffle - Win $25
Join and Win
Strain constraint error in free-size optimization
User: "Altair Forum User"
Altair Employee
Updated by Altair Forum User
Hello,
I have done a free-size optimization with a displacement constraint and it has been successfully solved. However the strains are huge and the model fails. I would like to constrain the strains to obtain the optimized model.
Now I have tried to do a free-size optimization with a 'composite strain' constraint and then an error appears. I understand that stresses and strains are related, so I don't understand why this error appears if I have defined a 0.007 maximum strain.
This is the error:
  *** ERROR # 1800 ***
  Stress/strain/force responses are applied to ply 1 which
  belongs to a topology or free-size domain. For stress-constrained
  topology or free-size optimization, please use the STRESS option
  on the design variable definition card.
This is my Response panel:
This is my Constraints panel:
This is my Design Variable panel:
1 - 5 of 51
    Altair Employee
    OP
    Hi @Samuel Caviedes
    DRESP1 stress is not supported for freesize or topology optimization problems.
    You need to enter the stress constraint on DSIZE itself.
    Goto FREESIZE panel>> PARAMETERS>> add STRESS constraint
    Altair Employee
    OP
    Hi @Prakash Pagadala
    I meant 'element strain' constraint. I know they're both related (stress/strain), but it's hard to find 'yield stress' empirically because it's related with the number of plies.
    Thanks,
    Samuel
    Altair Employee
    OP
    @Samuel Caviedes
    If you are running a three phase composite optimization you can use composite strain as a response during sizing of plies. But during freesize it is not.
    User: "Santosh G"
    Altair Community Member
    Updated by Santosh G
    I am trying to solve a topology optimization problem with DRESP2 card, mass fraction and stress are defined as responses which are also linked to equation. I am getting an error
     Stress/strain/force responses are applied to property 50 which
     This error occurs in module 'dppdrv1'.
    I am not able to understand this error
    Please help to overcome this error
    User: "Robert Lawson"
    Updated by Robert Lawson
    OS wants you to use the stress option on the DTPL card instead of a DRESP1.  However, that means you won't be able to pass that response to your DRESP2/DEQATN.  This might be a show-stopper for you.
