🎉Community Raffle - Win $25
Join and Win
Add filter option to table. I have to filter variable "cab1" based on alphabets and then select.
User: "Jouher_20929"
Altair Community Member
Updated by Jouher_20929
@tinh @Livil Lyle
1 - 11 of 111
    User: "tinh"
    Updated by tinh
    Hi
    the code is like this:
    $recess.sl rowadd row$I -values  [list entities ...
    lappend ::FullTable [list entities ...
    incr I
    button $w.bFilter -text Filter -command {::texample::p_Filter [::hwtk::inputdialog -title Filter -text Filter]}
    pack $w.bFilter
    proc ::texample::p_Filter {Filter {Index 1}} {
       if {![string equal '' $Filter]} {
          if {[string first * $Filter]==-1} {append Filter *}
          set NewList [lsearch -glob -nocase -all -inline -index $Index $::FullTable $Filter]
       } else {
          set NewList $::FullTable
       foreach row [$::recess.sl rowlist] {$::recess.sl rowdelete $row}
       foreach row $NewList {
          $::recess.sl rowadd row[incr i] -values $row
    OP
    @tinh
    WHere i sould add this to my above code
    OP
    image.png.36f6149145801d5fe77a526f76ffbd23.pngimage.png.8c655e0990bb1b85263fa718f9721e28.png
    User: "tinh"
    Updated by tinh
    I edited again the code. see above
    User: "Altair Forum User"
    Altair Employee
    Updated by Altair Forum User
    chua mot cot
    OP
    @tinh Its working. Thanks for this.
    But I want it in a different way.
    That is, I can select from checklist + when I filter and select = Total check
    That is , when I filter list should come as filter and will get selected , then comes without filter with selected....like appending and refreshing
    User: "tinh"
    Updated by tinh
    Can you do it base on my code?
    OP
    I was working on your code, but did not figure out to do this.
    User: "tinh"
    Updated by tinh
    I dont know how to answer because your question is not detail, so it seems that i write all script for you and finally it is ... not what you want! Very time consuming. So just devide your work to smaller tasks...
    OP
    @tinh you have wrongly taken. Your script is ok. What i want is when I filter and select, the selections should append to previous selections and come back for full selection
    User: "tinh"
    Updated by tinh
    It does not have a method to hide rows
    So once we delete rows (to show again filtered ones), last selection was lost
    When you filter it, set a global variable ::v_Filtering = 1, when you clear all selection (reset) => set it 0
    and in selectcommand proc, use that variable to decide to append or subtract or reset selected variable
    Do you understand?
