calculate inductance
User: "tehran"
Altair Community Member
Updated by tehran
Hello
who can help me to calculate inductance matrix for Electrical Machines in Altair Flux by using macros or any other ways?
Best regards
1 - 6 of 61
    User: "Alejandro Rodríguez"
    Altair Employee
    Updated by Alejandro Rodríguez
    Hello Tehran,
    Actually, you have several possibilities depending of your physics and your specific needs.
    The most simple one, only for linear problems with no magnetic saturation (i.e., rotor and stator modelled as ideal materials), is to use an specific sensor which measures inductance (it divides the total flux embraced by the coil between the current carried by this same coil, which is, in fact, an accurate definition of inductance for magnetic linear problems).
    You can find more accurate and sophisticated way to calculate this value for electric machines in our tutorial in 2D: Brushless IPM motor (embedded magnets), section 7.3. You will find it in the supervisor : Open example -> Technical tutorials -> Brushless IPM motor (embedded magnets) ->Computation of inductances and static torque.
    Another approach to simulate inductance in electric machines is to use the macro ComputeInductanceMatrix, you can load it into your project from Macros_Flux2D_Postproc. This is an advanced approach which uses frozen permeability techniques to take into account material saturation caused by the magnets where the machine is in working conditions. Please, notice that this macro can take some time to compute since it runs several simulations to accurately represents this physical phenomena.
    I hope the proposed documentation helps you with your inductance calculus. Please, do not hesitate to return to me in case you need further information about these topics.
    Best regards.
    User: "tehran"
    OP
    Updated by tehran
    Hello Tehran,
    Best regards.
    thank you for your help
    I want to calculate inductance in 3D simulation to compare with analytical calculation.
    Best Regards.
    User: "GlizaYuson"
    Updated by GlizaYuson
    You can find the way to calculate the  inductance matrix for Electrical Machines in Altair Flux here:
    https://docsbay.net/altair-flux-2019
     Hopefully it helps!
    User: "hardydragon"
    Updated by hardydragon
    Hello Alejandro Rodríguez,
    DELETE THIS POST
    Best Regards,
    HK
    User: "hardydragon"
    Hello Tehran,
    Best regards.
    'Another approach to simulate inductance in electric machines is to use the macro ComputeInductanceMatrix, you can load it into your project from Macros_Flux2D_Postproc. This is an advanced approach which uses frozen permeability techniques to take into account material saturation caused by the magnets where the machine is in working conditions. Please, notice that this macro can take some time to compute since it runs several simulations to accurately represents this physical phenomena.'
    What is difference between the incremental inductance calculated using delta flux / delta currents vs inductance matrix calculated by the ComputeInductanceMatrix? We did that and the values are completely different also the waveform shape is different.
    Best Regards,
    HK
    User: "Khanh Tran Vu"
    Updated by Khanh Tran Vu
    Hello Tehran,
    Best regards.
    Hi Alejandro Rodríguez,
    I followed your instruction and Altair flux document to compute Inductance matrix. After running the computation, Flux creates some parameters of Inductance. But when I choose the parameter, nothing happens, The I/O parameter was not created.
    Do you know what problems is this ?
    Thank you so much.
    Best regards,
