Altair RISE
Nominate Yourself Now!
what is the difference between compliance and weighted compliance?
User: "Sreekanth"
Altair Community Member
Updated by Sreekanth
1 - 3 of 31
    User: "Adriano Koga_20259"
    New Altair Community Member
    Accepted Answer
    Updated by Adriano Koga_20259
    There are a few topics around here about this.
    https://community.altair.com/community?id=community_search&spa=1&q=weighted compliance&t=&order=score&orderDesc=true
    Also if you take a look at OptiStruct documentation, under REsponses you would find the formulation of both of them.
    Anyway:
    1- Compliance is the sum of strain energy of your model, meaning the higher the value, more your model is deforming under the same load. This essentially gives you an inverse measure of stiffness, and that's why we tipically use a formulation of minimize Compliance for topology optimization, seeking for the stiffest structure.
    Another way of calculating compliance, under a fixed load, is basically:
    C = SUM (forces * displacements)
    if the load F is constant, the higher compliance, means higher displacements.
    Compliance is calculated for ONLY 1 Loadcase.
    2 - Weighted Compliance is just a combination of Compliance values for multiple loadcases.
    So, WCOMP = Sum(wi * Ci)
    wi is a weight scale factor
    Ci is the compliance of each loacase 'i'
    So, if you have 10 static loadcases in your model, you can combine them using WCOMP.
    the weight is optional, and by default 1.0 for all.
    But you could use the weightning factor to balance the numeric effect of each loadcase, as typically some loadcases have displacement(thus Comp) higher than others.
    If you don't balance them by using weighting factors, one loadcase can overcome all others, and drive the optimization all by itself.
    User: "Sreekanth"
    OP
    Thank you so much for your reply, Now I understand the difference
    User: "Rahul_P1"
    Altair Employee
    Updated by Rahul_P1
    HI Sreekanth,
    Please refer to the help documentation and OptiStruct user guide within the help which describe these concepts in detail
    also see Free eBook: Practical Aspects of Structural Optimization with Altair OptiStruct
