🎉Community Raffle - Win $25
Join and Win
How to Set Beam (B31) offset - Abaqus solver
User: "SaraZeta96"
New Altair Community Member
Updated by SaraZeta96
Hi!
I haven't found any option on Hypermesh regarding 1D Beam offsets.
My goal is to simply translate a rectangular section (B31 - Abaqus) so that the element axis (pink cross) is near the bottom side (red cross):
I tried the *BEAM GENERAL SECTION keyword, creating a general section, but changing the centroid or the shear center isn't what i wanted to obtain. It seems that the moments of inertia are central by default.
*BEAM GENERAL SECTION, ELSET=<>, SECTION=GENERAL
0.5 ,1.312 ,0.0 ,0.585 ,1.0 ,0.0 ,0.0
*CENTROID
0.0 ,0.264
*SHEAR CENTER
0.0 ,0.2
Thanks for the help! :)
P.S. Even if i tried to re-mesh my line component, setting (a) and (b) offsets, it seems that the software doesn't apply them. In the graphic area the created beams are still centered without offsets:
1 - 3 of 31
    User: "Lacie"
    Altair Employee
    Updated by Lacie
    Hi Sara,
    As of 2019.1, *BEAM SECTION OFFSET in the Abaqus profile was not supported within HyperMesh. Let me check with our team and documentation to see if this is still the case.
    Regards,
    Lacie
    User: "Lacie"
    Altair Employee
    Updated by Lacie
    I have just confirmed that the beam section offset in the Abaqus profile is not currently supported, but have also put in a feature request to have this added in 2021.1 release.
    User: "SaraZeta96"
    OP
    Thak You! :)
