how to model a system which goes down grade with constant velocity
hi
i have given constant velocity for the joint and have given contacts between the roller and floor .so for this model when its goes down the slope it over rides the initial condition that i have given for the joint, that is it rolls freely as in a free fall .Is there anyway so that i can make the system run with constant velocity even on a slope with down gradient
thank you
hi sorry to trouble you, this sounds too complex,i went through the help.where should iinput this function? should it be written in template,can u give me a example how it should be used.
1.) My condition is to make the system run with a constant velocity on the slope
2.)how to use Gcon for the rear revolute joint in the pic so that entire system runs on a constant velocity in the slope
lets consider angular velocity of the rear wheel to be 2 rad/sec . so that it runs with the constant velocity on the slope
thank you
Hi
Thank you I found a solution. I used the step function.
