1 - 4 of
41
- Add Calculated Field that will include values only for odd numbered rows.
- If( Mod ( Rowno(), 2) = 0, [Account Number], "")
- Ditto that column.
- Add Calculated Field that will include values only for even numbered rows.
- If( Mod ( Rowno(), 2) = 1, [Account Number], "")
- Add Calculated Field that will take the value from the odd or even, depending on if the current row is even or odd. This will be your "Previous Row" field, which can be referenced in subsequent formulas/functions.
- If( Mod ( Rowno(), 2) = 0, [Even Values], [Odd Values])
- Delete the even column.
- Delete the odd column.
Hello Jean,
The previous row of any column can be derived within a single table using current functions/formulas. These are the steps:
By adding additional steps, you can generate columns that present the value three, four or n rows previous.
If you need to know subsequent rows' values, you would first need to sort in reverse row number order, then follow these steps, then re-sort in the original order.
Good Luck!
Stephen
Bonjour Baba,
Merci Stephen, mais je ne vois pas comment cela peut fonctionner : je réexplique mon problème en prenant l'exemple de la pièce jointe :
quand la VALEUR de la ligne précédente = la VALEUR de la ligne en cours alors je mets mon champ RESULTAT à 1 sinon il est égal à CUMUL+1
Bien cordialement,
Hi Jean!
How are you? It depends on what you're trying to accomplish. It's possible to do something like this with some operations like an Unpivot and a Pivot. Can you give a little more insight on what you're try to accomplish?
Best Regards,
Baba
