Centrifugal forces
Hi,
I would like to apply a centrifugal force to my model so I created a loadcollector with card image RFORCE but I don't know what the fields refer.
I discovered that A refers to angular veolcity, RACC to angular acceleration, but what do the fileds G, CID, R1, R2, R3, IDRF refer to?
Hi
enter menu Help of hypermesh
But I see it is very slow while browsing help documents, especially from v2017
So I usually enter folder <install dir>\help
and then use window search tool to search files, just enter 'rforce' in search box, the html file will appear soon
How to calculate R1 R2 and R3? I didn't fullt get it.
They are the versor components of rotation axis. For example : rotation axis parallel to z direction -> R1=0 R2=0 R3=1. In general you can use a vector parallel to rotation axis.
Hi
you can find it in optistruct reference help
G - origin of rota vector
CID - coordinate system of vector
R1R2R3 - components of vector
IDRF - id of element set applied this force
